what is the biggest baddest turbo you can put in a 2g
i have the big 16g when i was installing the bc it said you can hook it up two ways one helps it spool faster but has spikes and the other has less spikes but takes a lil longer to spool i went the way with less boost spikes if i change that do you think i would notice a very big difference and btw TA i freaking love your eclipse it is so sexy
Thanks. Its actually sitting in my garage right now with the motor pulled out of it
Still deciding how to buiild it..
Where did you find this about hooking it up different to get different responses? How do you have it hooked up?
Still deciding how to buiild it..Where did you find this about hooking it up different to get different responses? How do you have it hooked up?
well on the vfaq it says you can t it into the line from turbo to waste gate but i just have the vacum line from the turbo to the mbc to the waste gate. is that incorrect? i heard your going with a 6 bolt. is that cuz your 7 bolt got crankwalk? i just had a rebuilt 7 bolt put in with about 20000 mi on it. so hopefully it wont happen for a long time
Ya, my motor got crankwalk.. I have it completely out and im gonna be tearing it apart getting ready to put my 7 bolt head on my 6 bolt block.. But I have a lot going on right now so I prolly wont get to it till this weekend sometime.
ORIGINAL: RCJr9186
well there arent any real huge hp running 2g's on here..
GT42R is the turbo of choice for most of the big power guys. For street/strip 2.0L I would recommend along the lines of GT35R, 61mm or FP3065 turbo. For the 2.3-2.4L I would recommend the t67 or FR3575 for some real power.
