What is the highest psi i can run?
Ok the car is a 1g talon TSi AWD.
Mods... SAFC II, Wideband, MBC, Intake Mani, 660 injectors, 190lph fuel pump, SBR Bastard 20g turbo fully ported, Type S BOV, FMIC, Intake, Exhaust, plugs+wires, Ported mani. Im wondering what kinda PSI it can take |
RE: What is the highest psi i can run?
well with a good tune you should be able to run around 22-23 psi easy
most?
ORIGINAL: Sebba most? |
awesome...
This is my friends car im just doing a lil researsh. We are also thinking about rebuilding the motor with possibly a 2.3l stroker kit |
Except for that turbo you pretty much described my car at the end of this summer.lol
ORIGINAL: paintballproam Except for that turbo you pretty much described my car at the end of this summer.lol And sebba its probably alot easier just to build up the current bottom end with pistons and rods rather than stroke out the block you have. |
What is the max I could run with my setup? Also running 15 psi wha HP should I be at. Also what is the next thing I should upgrade? School starts soon so I can't fork out a bunch of cash. Also should I be runnig a colder spark plug when runnig over 14 psi?
Injen intake Joe P MBC Greddy metal upper and lower IC pipes Greddy type s BOV Big T28 60 trim turbo Ported o2 housing 3" turbo bac Tsudo exhaust Boost guage Greddy Turbo Timer 8.0:1 Pistons Cometic head gasket Everything else is stock |
http://1320video.com/vids/12.28RedRumDyno.wmv
It was fine for a few pulls, it was making 442hp at 35psi |
ORIGINAL: 99clipsgst What is the max I could run with my setup? |
