what is the turbo called tha the evo 8 uses?
Old 11-16-2006 | 11:50 PM
Simss's Avatar
Default what is the turbo called tha the evo 8 uses?
is it the 16g? or no?
Old 11-17-2006 | 12:08 AM
silvercoupe97's Avatar
Default RE: what is the turbo called tha the evo 8 uses?
Yes.
Old 11-17-2006 | 01:09 AM
Simss's Avatar
okay cool... thanks
Old 11-17-2006 | 01:12 AM
Oh and don't forget the EVOs use a twin scroll 16G and not a DSM 16G.
Old 11-17-2006 | 10:44 AM
Twin scroll big 16G and depending on ther year the hot sides are different. 05s had a bigger hot side (10.5) and earlier had a 9.8
Old 11-17-2006 | 04:11 PM
Simss's Avatar
so does that mean that i couldnt put a 16g from a evo on my eclipse even with the 16g kit?
Old 11-17-2006 | 07:44 PM
ORIGINAL: Simss
You can't use the EVOs 16g with a 2G install kit.
Did you read any of the info in your other EVO turbo thread? https://mitsubishiforum.com/m_98406/tm.htm Maybe you should look at it again...
If you want a 16G with a 10cm exhaust side, get a Hahn Super 16G.
Old 11-17-2006 | 07:46 PM
ORIGINAL: silvercoupe97
ORIGINAL: Simss
Ya man both silvercoupe and I told you exactly why you cant do it
Old 11-18-2006 | 06:36 AM
Simss's Avatar
Yeah, i understand why i cant do it, I Just got confused on the whole name thing between the evo 16g and the dsm 16g I thought they were the same?
Old 11-18-2006 | 10:44 AM
Not the newer EVO 16Gs they are all different. The EVO III (3) are ones you could use
OutlanderGT
10-20-2013 01:08 AM
dantes
10-25-2011 09:01 AM
EdZorX
05-23-2006 12:36 PM
StreetAlliance
03-11-2006 03:47 PM
jeffery0266
02-28-2006 02:01 AM
Quick Reply: what is the turbo called tha the evo 8 uses?
