do the outlander sport uses the same brake pads
Old Oct 19, 2013 | 02:16 AM
OutlanderGT's Avatar
Default do the outlander sport uses the same brake pads
If I get pads listed for the sport will it work on my GT
Old Oct 19, 2013 | 12:56 PM
milliesdad's Avatar
I would doubt it.
Take the guess work out and order for the correct vehice That way you know that they will work.
Old Oct 20, 2013 | 01:08 AM
Burtonrider10022's Avatar
Outlander Sport uses different calipers, so I'm going to doubt that it uses the same pads.
ETA:
Originally Posted by Antilock Braking System (ABS)
The braking system on Mitsubishi's compact crossover is essentially mechanically identical to that found on the larger Outlander SUV, save for a few critical design changes for improved performance and safety.
The ability of the Outlander Sport to reduce its speed rapidly in emergency braking situations has also been improved with a design revision to the brake booster. When the system concludes that the driver is in a situation that requires instantaneous braking (the system determines this by a quicker than normal operation of the brake pedal), a mechanical locking mechanism inside of the brake booster is momentarily deactivated, thus increasing the braking system's power beyond that of a normal braking situation.
Another key difference is that the Outlander Sport features new brake calipers that reduce drag by a full 30 percent to those equipped on the Outlander in yet another comprehensive effort on the behalf of Mitsubishi to help improve fuel economy. The Outlander SUV, Outlander Sport CUV makes use of 16-in. ventilated brake discs at all four corners, but with a larger diameter single-piston on the front brakes to the Outlander's dual-piston design, with a slightly smaller single-piston utilized on each of their vehicle's rear rotors.
dantes
Oct 25, 2011 09:01 AM
marinetanker504
Oct 11, 2008 05:22 AM
serenabkhan
Nov 23, 2007 05:44 PM
Simss
Nov 18, 2006 10:44 AM
EdZorX
May 23, 2006 12:36 PM
