boost creep
Old Feb 12, 2007 | 06:04 PM
RCJr9186's Avatar
Default boost creep
aight... i'm lookin at gettin either the fp352 or fp3065 for my gsx... i'm gonna buy it here in about 2 weeks. i have heard this term before but i wanted to completely understand what exactly it is... FP's website says "Boost pressure can be set as low as 14psi without ANY boost creeping at higher RPM." what is boost creep?
Old Feb 12, 2007 | 07:18 PM
silvercoupe97's Avatar
Default RE: boost creep
The simple answer is...
That's when you see your boost gauge needle slowly go past your preset boost level.
The basic detailed version is...
This happens when some of your exhaust cannot be relieved by the wastegate (usually because the flapper is too small) and causes the turbine wheel to continue to spool up..I think of it as a "flapper overrun" or too much exhaust, but not enough flapper, lol. This is why some folks get a larger flapper, a 34mm or an external.
This usually happens at lower boost settings too, not to much at higher boost levels.
*just an example number*
Old Feb 12, 2007 | 08:52 PM
External Tial is the only way to go!
Old Feb 13, 2007 | 10:11 AM
ORIGINAL: Sebba
agreed. Go either a 38mm or a 44mm
Old Feb 13, 2007 | 11:34 AM
RCJr9186's Avatar
ok, good stuff, thanks guys. they sell the 44mm tial w/ it and it looks SOOOO ****IN good bolted up!!!!! heres a pic:
TIAL 44mm wastegate.
go to the bottom on the right pic, click it to enlarge it.... SO nice!
Old Feb 13, 2007 | 08:10 PM
That looks awesome even with the stock manifold. Thats cool how they did that. I have never seen them actually weld the fitting on like that... hmmm intresting.
Looks great with the new manifold without all the rust and stuff.
Anyone know if there is a way of chemically treating it to prevent all rust and stand up against extreme heat?
Old Feb 13, 2007 | 08:34 PM
You'll have to clean the mani and then spray some very high temp paint or clear onto it Sebba. They have 2k degree paint, or 2400 deg paint. I have some, but I can't remember which. Either way, it's up there in temp. Made by VHT btw. That's high enough, you're in big trouble if it's not, lol...yikes.
Old Feb 14, 2007 | 12:33 AM
LOL i can imagine
Old Feb 14, 2007 | 10:55 AM
RCJr9186's Avatar
FP sells that manifold painted like that to withstand the heat (unles you lean the **** out of it of course lol) and that is what mine will look like exactly... sooooooooo freakin nice!
ridingDSM0201
Jun 13, 2008 11:24 PM
lhausi2
Feb 22, 2008 03:56 PM
anko_kun
Dec 24, 2006 07:48 PM
n2daizo123
Apr 18, 2006 08:46 PM
Pinser555
Feb 28, 2004 03:55 PM
