Need help painting plastic, stuff keeps getting orange peel!
Old May 5, 2008 | 10:28 PM
estraw's Avatar
Default RE: Need help painting plastic, stuff keeps getting orange peel!
ORIGINAL: Kaede.Noir
also if youre touching it with greasy fingers or something like that would cause the orange peel... but im sure youre looking after that huh?
this could also happen if you didnt rince all the soap off. something to do is get a chemical called hi-solve and clean everything off with it thats gonna get painted. it will get rid of all the grease on the surface and will probably fix your problem
Old May 5, 2008 | 11:03 PM
lhausi2's Avatar
dude this is wut you do, sanding with 400 is good, but keep going all the way up to 1000 at least if not 2000. then you go over it with a tack cloth, it's a special cloth used in autobody right before you paint it(after you cleaned it) to get all the small particles off of it, then you apply self etching primer that'll adhere better to anything. then you wetsand it with 800 grit and then wetsand with 1000, because orange peel starts in the primer, not the actual paint and works its way up.
Old May 6, 2008 | 02:23 PM
jpmontero98's Avatar
that would cause fish eyes, wax and grease remover works well to prevent that
Harvey32
Jul 21, 2015 10:27 PM
eclipseGS98
Dec 22, 2008 07:54 PM
AdamBNYC
Dec 16, 2008 12:00 PM
evocyn
Mar 17, 2008 12:28 PM
novandar
Feb 5, 2005 04:04 PM
