Need some help with an engine (420A?)
Old May 25, 2006 | 11:37 PM
Sanguinius's Avatar
Default RE: Need some help with an engine (420A?)
That's fine and dandy but there will be valves open I'm trying to test for bent valves before doing the timing belt. If the belt is on and whatnot that will work but the belt isn't. Know what I'm trying to say? I want to test it before doing the work to replace it. With the cam stationary I shouldn't see any compression in at least 1 if not more cylinders.
Old May 25, 2006 | 11:38 PM
oh yea thats right. I forgot thats what they did on my car when mine went. I remeber them saying there was zero compression on 3 cylinders. , it was bad
Old May 25, 2006 | 11:42 PM
Sanguinius's Avatar
I have 30 on the #1 0 on 2 and 3 and 40 on #4 with a stationary camshaft I'm hoping it stopped with them up enough to not hit and bend... Slim chance I'm sure...
Old May 25, 2006 | 11:47 PM
yea id say pretty damn slim. Sounds liike your looking at replacing at least a couple valves though.
Old May 25, 2006 | 11:56 PM
Sanguinius's Avatar
I'm hoping not... She can't afford the timing belt let alone a valve job. Not to mention the gaskets she'll now need...
Old May 26, 2006 | 12:18 AM
slow420a's Avatar
I promess a valve is bent. If your just driving at a crusing speed each piston is moving up and down 2500 times a min, thats 41 times a second... at least one valve is bent.
Old May 26, 2006 | 02:13 AM
Ya man it is almost impossible to not bend a valve on an interference motor. I bet at least one is if not more. The problem is to make sure they didnt crack any pistons
Old May 26, 2006 | 03:26 AM
gump's Avatar
just go to a pick and pull there are hundreds of eclipses and neons in there.
Old May 26, 2006 | 09:39 AM
thats probably your best bet is to buy a head from a junk yard...the same thing happened to my sister and were now in the process of getting a cyilinder head...its eaisier than ripping the whole thing apart
Old May 30, 2006 | 08:32 PM
Sanguinius's Avatar
Either my friend got INCREDIBLY lucky or I dunno maybe the SOHC is a non interference motor. I took 7.5 hours Monday to do the timing belt. Turns out the water pump is fine (The belt was old and HADN'T been replaced last year as she thought). After re timing the car 4 times (I'll explain THAT fiasco in a minute here) I finally got her running and she purs like a kitten. The engine makes NO noise whatsoever. So if there IS a bent valve then it's BARELY bent if at all and I told her already that there MAY be one and to tuck some away here and there to do the head job later.
Anyways ON to the story. I'm going by this ultimate timing book we have. This book lists every engine known and how to time each one and all steps to install a new timing belt. So for DiamlerChrysler the 2.0L SOHC after removing the timing belt the book informs me to line the crankshaft up at TDC via the arrows on the crank pulley and the oil pump housing. Done. Now it says to back the crank off 3 notches. Fine... Done. Align the camshaft to TDC. Done. Then it says to back the crankshaft off another 1/2 a notch. So I do that. Now install the timing belt and bring the crankshaft forward by 1/2 a notch to TDC... Now wait a sec... I thought I was 3 1/2 notches away from TDC... So do I go 1/2 or do I go to TDC?... I try both ways... Nothing... I tried another variation of it then decided to go back to the shadetree method. I threw the damn book across the shop, Took out #1 plug, stuck a long @$$ 1/4" extension into the hole and found TDC myself. (Which actually happened to be 1/2 notch AFTER the mark... Hhhhmmmm....) I then proceeded to install the belt, turn the engine twice by hand (That thing had some compression lemme tell you...), and then finally turn the key. And BAM she starts right up. NEVER again will I go by a freakin book... (Not a generic one at least).
