Need transmission
Old Dec 6, 2003 | 11:42 PM
drpcexe's Avatar
Default Need transmission
Please help I need a transmission for a 98 mitsubishi eclipse 2.0 liter non-turbo automatic.
Old Jan 28, 2004 | 01:48 PM
91eclipse's Avatar
DUDE,</P>
I THINK MY TRANS IS GOING OUT AS WELL. I HAVE A 91 ECLIPSE NON TURBO. HOW WAS YOUR TRANS ACTING BEFORE IT WENT OUT? MINE WILL SHIFT FROM 1ST TO 3RD FINE...BUT IT WILL NOT GO IN 4TH ECT....PLEASE HELP AND GIVE ME SOME ADVICE. I WILL KEEP MY EYE OUT FOR YOU A TRANS FOR YOUR ECLIPSE HERE IN OHIO.</P>
Old Apr 4, 2004 | 07:39 PM
Eric Cannon's Avatar
don't know if this will help but you can get a 5 speed turbo tranny's from buscar racing for like 1900 but I am not sure about automatics none turbo one. You might give them a try. If you run across ne turbo engines and trannys or just trannys give put a thread in. Sometimes I run across non turbo ones and I will try to send you the info if I do.
Old Apr 4, 2004 | 08:20 PM
SpyderGS's Avatar
You are very much in luck, you can find those transmissions for you car in abundance at junkyards. They are the same as the ones in Dodge Avengers, sebrings, and neons. Getting it cleaned and rebuilt should cost around $600 from a shop. Good luck.
Old Apr 5, 2004 | 02:18 AM
spydergs are you refering to the transmission I need for my 97 gst. I thought that the tranny's in the non turbo cars were like that of the neon but not for the turbos as for the Dodge Avengers and sebrings that is the first I have heard of anything relating to a 2g eclipse. If I can use these trannys do you know which models of the cars metioned would have the correct one. I asume they have a few different engines in those cars although I am not to familar with them personally.
Old Apr 6, 2004 | 05:08 PM
Spyderman9803's Avatar
The 420a(chrysler motor)was used in neons, avengers, and sebrings. The 4g63 was used in the GS-T(mitsubishi motor). That help any Eric? </P>
Old Apr 7, 2004 | 01:34 AM
That is what I thought the case was about the motors but since I am fairly new to these cars I wanted to make sure. thanks
Old Apr 7, 2004 | 01:45 AM
I fully understand you. Everybody has to learn at some point. Just don't be afraid to ask. Heck, I'm still learning myself on alot of things.<IMG src=smileys/smiley2.gif border="0"></P>
Old Apr 7, 2004 | 01:54 AM
Thanks for the encouragement, i am not sure this is really relavent but I have grown up around austin mini (or mini coopers as most now them) and have learned a lot about engines and trannys threw building a rebuilding them. This is just a new ball game for me so to say but if you know anyone with a mini, wants one or just has question about them I am a wealth of knowlege. Sorry for going off topic.
Old Apr 7, 2004 | 04:05 PM
91eclipse's Avatar
How'd did this old mess thing get back on here....oh yeah my tranny did go!
