Saleen S7 TT W/Blown motor!!
Old 12-30-2007 | 12:53 PM
_Adrian_'s Avatar
Default RE: Saleen S7 TT W/Blown motor!!
dbl post
Old 12-30-2007 | 01:07 PM
nick_200321's Avatar
lol sebba just got pwned
Old 12-30-2007 | 02:56 PM
sk8dudety's Avatar
hahaha, at least it was a good one... thats sweet though!
Old 12-30-2007 | 07:58 PM
What in the ****?
I said the Saleen S7 has nothing to do with Ford... and it doesnt. There is ZERO Ford components in the car.
I was stating a fact, no need to be a ***** about it.
Old 12-30-2007 | 08:53 PM
_Adrian_'s Avatar
ORIGINAL: Sebba
What in the ****?
yes they do!!!
they use ford blocks and headsbut from that point on they use their own components.
they buy the ford blanks and the machine them in house.
and for a fact... that saleen in the background
uses a stadard 5.4L 3V with some beefed up internals , Saleen spec ECU calibration and a blower
and thats as far as the drivetrain.
http://www.saleen.com/s331_sc_specs.htm
thats for the 331
as for as the S7 goes its nothig more that aoldschool fordpushrod big blockthats been casted in aluminum for saleen.
Also 90% of the Ford aluminum components are casted at NEMAK in windsor, ontario.
Old 12-30-2007 | 09:19 PM
damn sebba, looks like your outa your league, 2 for adrian, 0 for sebba[8D]
Old 12-30-2007 | 10:56 PM
tidus10's Avatar
ORIGINAL: _Adrian_
ORIGINAL: Sebba
What in the ****?
yes they do!!!
thats for the 331
quite impressive....but i can copy and paste..
ENGINE
[align=left][/align]
Type
[align=left]All-aluminum V8, 2-valve pushrod [/align]
Displacement
[align=left]7.0 liters[/align]
Bore and stroke
[align=left]4.125 x 4.00 in. (104.8 x 101.6 mm)[/align]
Compression ratio
11.0:1
Pistons
[align=left]Forged aluminum[/align]
Connecting rods
[align=left]4340 forged billet steel[/align]
Crankshaft
Induction system
[align=left]Air enters a roof intake, passes through a 90-mm mass air meter, feeding a carbon fiber plenum; from the plenum, air is routed to two twin-ball-bearing turbos, passes through an oval bore-throttle body into an aluminum intake manifold with eight individual runners[/align]
Cylinder heads
[align=left]CNC machined, all-aluminum, Saleen high-flow[/align]
Valves
[align=left]Stainless steel with titanium retainers;
Intake: 2.125 in. (54.0 mm); Exhaust: 1.625 in. (41.3 mm);
Beryllium exhaust seats
[/align]
Valve train
[align=left]Solid lifter/roller rocker[/align]
Exhaust system
[align=left]
Stainless steel high flow with merge collector incorporating dual catalysts per cylinder bank and EGR system; two twin-ball-bearing turbos with 44-mm wastegates
(Note: The 2006 S7 is not OBD II compliant and not available for sale or use in California)[/align]
Required fuel
[align=left]91 octane[/align]
Alternator
[align=left]140 amps[/align]
Battery
[align=left]12 volts[/align]
Front Engine Accessory Drive (FEAD)
[align=left]Compact drive system with side-mounted water pump[/align]
Emission control system
[align=left]dual, heated oxygen sensors
per bank; high-volume EVAP system
[/align]
Fuel system
[align=left]High-capacity returnless with 42 lb/hr injectors[/align]
Oil system
[align=left]High-vacuum dry sump configuration;
Capacity: 12.6 qt (12.0 liters); aluminum oil tank
[/align]
Horsepower
[align=left]750 bhp @ 6300 rpm[/align]
Torque
[align=left]700 lb-ft @ 4800 RPM[/align]
Redline
[align=left]6250 rpm[/align]
Old 12-30-2007 | 11:50 PM
Thank you. That motor has nothing to do with Ford. I had this discussion with someone already.
Dont be a *****, usually i dont state a fact unless im 100% sure, and on the off chance that im wrong, i will step down and admit it. RIght now your just proving to everyone how much of a ****** you are.
Old 12-31-2007 | 12:01 AM
tjbiker031's Avatar
tru dat
Old 12-31-2007 | 12:10 AM
Lets give the guy a little credit at least. The interior has 'ford' aspects to it, such as the air vents that look like they came off of a ****ing V6 mustang. The brakes are awesome, bu they squeel like a raped pig. Hmmm...
I was actually defending Ford by saying the motor had nothing to do with them. Im not a Ford lover, i dont need to butt love Ford, i just like the facts. I was always told that the original n/a Saleen S7 had a Ford 'inspired' engine, but that was as close as it got.
Yes, i understand Saleen like to take Fords already existing models and **** with them, but thats not the case here. They cut corners on the 'unimportant' parts and cut down to the *****. In a way i kind of like it, but for that much money? I think a little more attention to detail was in order.
Example, a Lotus. It has those same ****ing ugly *** vents in it. However, the car is also a 10th the price. Now that i can understand, and live with. Not to mention the brakes dont sound like nails on a chalk board.
Now, please quit being a vagina.
Quick Reply: Saleen S7 TT W/Blown motor!!
