Saleen S7 TT W/Blown motor!!
What in the ****?
I said the Saleen S7 has nothing to do with Ford... and it doesnt. There is ZERO Ford components in the car.
I was stating a fact, no need to be a ***** about it.
ORIGINAL: Sebba
What in the ****?
What in the ****?
they use ford blocks and headsbut from that point on they use their own components.
they buy the ford blanks and the machine them in house.
and for a fact... that saleen in the background
uses a stadard 5.4L 3V with some beefed up internals , Saleen spec ECU calibration and a blower
and thats as far as the drivetrain.
http://www.saleen.com/s331_sc_specs.htm
thats for the 331
as for as the S7 goes its nothig more that aoldschool fordpushrod big blockthats been casted in aluminum for saleen.
Also 90% of the Ford aluminum components are casted at NEMAK in windsor, ontario.
ORIGINAL: _Adrian_
yes they do!!!
ORIGINAL: Sebba
What in the ****?
What in the ****?
thats for the 331
thats for the 331
quite impressive....but i can copy and paste..
ENGINE
[align=left][/align]
Type
[align=left]All-aluminum V8, 2-valve pushrod [/align]
Displacement
[align=left]7.0 liters[/align]
Bore and stroke
[align=left]4.125 x 4.00 in. (104.8 x 101.6 mm)[/align]
Compression ratio
11.0:1
Pistons
[align=left]Forged aluminum[/align]
Connecting rods
[align=left]4340 forged billet steel[/align]
Crankshaft
Induction system
[align=left]Air enters a roof intake, passes through a 90-mm mass air meter, feeding a carbon fiber plenum; from the plenum, air is routed to two twin-ball-bearing turbos, passes through an oval bore-throttle body into an aluminum intake manifold with eight individual runners[/align]
Cylinder heads
[align=left]CNC machined, all-aluminum, Saleen high-flow[/align]
Valves
[align=left]Stainless steel with titanium retainers;
Intake: 2.125 in. (54.0 mm); Exhaust: 1.625 in. (41.3 mm);
Beryllium exhaust seats[/align]
Valve train
[align=left]Solid lifter/roller rocker[/align]
Exhaust system
[align=left]
Stainless steel high flow with merge collector incorporating dual catalysts per cylinder bank and EGR system; two twin-ball-bearing turbos with 44-mm wastegates
(Note: The 2006 S7 is not OBD II compliant and not available for sale or use in California)[/align]
Required fuel
[align=left]91 octane[/align]
Alternator
[align=left]140 amps[/align]
Battery
[align=left]12 volts[/align]
Front Engine Accessory Drive (FEAD)
[align=left]Compact drive system with side-mounted water pump[/align]
Emission control system
[align=left]dual, heated oxygen sensors
per bank; high-volume EVAP system[/align]
Fuel system
[align=left]High-capacity returnless with 42 lb/hr injectors[/align]
Oil system
[align=left]High-vacuum dry sump configuration;
Capacity: 12.6 qt (12.0 liters); aluminum oil tank[/align]
Horsepower
[align=left]750 bhp @ 6300 rpm[/align]
Torque
[align=left]700 lb-ft @ 4800 RPM[/align]
Redline
[align=left]6250 rpm[/align]
Thank you. That motor has nothing to do with Ford. I had this discussion with someone already.
Dont be a *****, usually i dont state a fact unless im 100% sure, and on the off chance that im wrong, i will step down and admit it. RIght now your just proving to everyone how much of a ****** you are.
Lets give the guy a little credit at least. The interior has 'ford' aspects to it, such as the air vents that look like they came off of a ****ing V6 mustang. The brakes are awesome, bu they squeel like a raped pig. Hmmm...
I was actually defending Ford by saying the motor had nothing to do with them. Im not a Ford lover, i dont need to butt love Ford, i just like the facts. I was always told that the original n/a Saleen S7 had a Ford 'inspired' engine, but that was as close as it got.
Yes, i understand Saleen like to take Fords already existing models and **** with them, but thats not the case here. They cut corners on the 'unimportant' parts and cut down to the *****. In a way i kind of like it, but for that much money? I think a little more attention to detail was in order.
Example, a Lotus. It has those same ****ing ugly *** vents in it. However, the car is also a 10th the price. Now that i can understand, and live with. Not to mention the brakes dont sound like nails on a chalk board.
Now, please quit being a vagina.
