Saleen S7 TT W/Blown motor!!
#21
ORIGINAL: tidus10
quite impressive....but i can copy and paste..
ENGINE
[align=left][/align]
Type
[align=left]All-aluminum V8, 2-valve pushrod [/align]
Displacement
[align=left]7.0 liters[/align]
Bore and stroke
[align=left]4.125 x 4.00 in. (104.8 x 101.6 mm)[/align]
Compression ratio
11.0:1
Pistons
[align=left]Forged aluminum[/align]
Connecting rods
[align=left]4340 forged billet steel[/align]
Crankshaft
Induction system
[align=left]Air enters a roof intake, passes through a 90-mm mass air meter, feeding a carbon fiber plenum; from the plenum, air is routed to two twin-ball-bearing turbos, passes through an oval bore-throttle body into an aluminum intake manifold with eight individual runners[/align]
Cylinder heads
[align=left]CNC machined, all-aluminum, Saleen high-flow[/align]
Valves
[align=left]Stainless steel with titanium retainers;
Intake: 2.125 in. (54.0 mm); Exhaust: 1.625 in. (41.3 mm);
Beryllium exhaust seats[/align]
Valve train
[align=left]Solid lifter/roller rocker[/align]
Exhaust system
[align=left]
Stainless steel high flow with merge collector incorporating dual catalysts per cylinder bank and EGR system; two twin-ball-bearing turbos with 44-mm wastegates
(Note: The 2006 S7 is not OBD II compliant and not available for sale or use in California)[/align]
Required fuel
[align=left]91 octane[/align]
Alternator
[align=left]140 amps[/align]
Battery
[align=left]12 volts[/align]
Front Engine Accessory Drive (FEAD)
[align=left]Compact drive system with side-mounted water pump[/align]
Emission control system
[align=left]dual, heated oxygen sensors
per bank; high-volume EVAP system[/align]
Fuel system
[align=left]High-capacity returnless with 42 lb/hr injectors[/align]
Oil system
[align=left]High-vacuum dry sump configuration;
Capacity: 12.6 qt (12.0 liters); aluminum oil tank[/align]
Horsepower
[align=left]750 bhp @ 6300 rpm[/align]
Torque
[align=left]700 lb-ft @ 4800 RPM[/align]
Redline
[align=left]6250 rpm[/align]
ORIGINAL: _Adrian_
yes they do!!!
they use ford blocks and headsbut from that point on they use their own components.
they buy the ford blanks and the machine them in house.
and for a fact... that saleen in the background
uses a stadard 5.4L 3V with some beefed up internals , Saleen spec ECU calibration and a blower
and thats as far as the drivetrain.
ORIGINAL: Sebba
What in the ****?
I said the Saleen S7 has nothing to do with Ford... and it doesnt. There is ZERO Ford components in the car.
I was stating a fact, no need to be a ***** about it.
What in the ****?
http://www.saleen.com/s331_sc_specs.htm
thats for the 331
as for as the S7 goes its nothig more that aoldschool fordpushrod big blockthats been casted in aluminum for saleen.
Also 90% of the Ford aluminum components are casted at NEMAK in windsor, ontario.
thats for the 331
ENGINE
Type
Displacement
Bore and stroke
Compression ratio
11.0:1
Pistons
Connecting rods
Crankshaft
Induction system
Cylinder heads
Valves
Valve train
Exhaust system
[align=left]
Required fuel
Alternator
Battery
Fuel system
Oil system
Horsepower
Torque
Redline
im not quoting ....
i've spent 8 ****in hours on a god damm seminar...
pretty much got drilled in my head..
the links i posted were for verification just in case you "ford experts" were doubting a ford master tech.
trust me..
i dont need some snoty nose kid to tell me what my job is about.
the whole discusion started with saleen not using ford parts...
and i proved you wrong sebba...
so quit your whining and just shut up!!
they also manufacture it specialy for al their SVT teams and ALMS series use the same block... what a shocker...
as long as theres a ford logo on the block it doesnt matter who its made for because the block is still made by ford.
#22
Snot nose kid... hmmm. Thats not ignorant.
Im not trying to be a ***** about this, you are.
I just asked where it said that the S7 TT was built by Ford. So far you havnt provided that.
#23
ORIGINAL: _Adrian_
umm ..
im not quoting ....
trust me..
umm ..
im not quoting ....
trust me..
This got blown outta control really quick and its uncalled for...
Thanks for you enlightenment about the Ford/Saleen relationship but you could have done it without being so damn touchy about the situation.
