Saleen S7 TT W/Blown motor!!
Old Dec 31, 2007 | 12:28 AM
  #21
_Adrian_'s Avatar
Default RE: Saleen S7 TT W/Blown motor!!
ORIGINAL: tidus10
ORIGINAL: _Adrian_
ORIGINAL: Sebba
What in the ****?
I said the Saleen S7 has nothing to do with Ford... and it doesnt. There is ZERO Ford components in the car.
I was stating a fact, no need to be a ***** about it.
yes they do!!!
they use ford blocks and headsbut from that point on they use their own components.
they buy the ford blanks and the machine them in house.
and for a fact... that saleen in the background
uses a stadard 5.4L 3V with some beefed up internals , Saleen spec ECU calibration and a blower
and thats as far as the drivetrain.
http://www.saleen.com/s331_sc_specs.htm
thats for the 331
as for as the S7 goes its nothig more that aoldschool fordpushrod big blockthats been casted in aluminum for saleen.
Also 90% of the Ford aluminum components are casted at NEMAK in windsor, ontario.
quite impressive....but i can copy and paste..
ENGINE
[align=left][/align]
Type
[align=left]All-aluminum V8, 2-valve pushrod [/align]
Displacement
[align=left]7.0 liters[/align]
Bore and stroke
[align=left]4.125 x 4.00 in. (104.8 x 101.6 mm)[/align]
Compression ratio
11.0:1
Pistons
[align=left]Forged aluminum[/align]
Connecting rods
[align=left]4340 forged billet steel[/align]
Crankshaft
Induction system
[align=left]Air enters a roof intake, passes through a 90-mm mass air meter, feeding a carbon fiber plenum; from the plenum, air is routed to two twin-ball-bearing turbos, passes through an oval bore-throttle body into an aluminum intake manifold with eight individual runners[/align]
Cylinder heads
[align=left]CNC machined, all-aluminum, Saleen high-flow[/align]
Valves
[align=left]Stainless steel with titanium retainers;
Intake: 2.125 in. (54.0 mm); Exhaust: 1.625 in. (41.3 mm);
Beryllium exhaust seats
[/align]
Valve train
[align=left]Solid lifter/roller rocker[/align]
Exhaust system
[align=left]
Stainless steel high flow with merge collector incorporating dual catalysts per cylinder bank and EGR system; two twin-ball-bearing turbos with 44-mm wastegates
(Note: The 2006 S7 is not OBD II compliant and not available for sale or use in California)[/align]
Required fuel
[align=left]91 octane[/align]
Alternator
[align=left]140 amps[/align]
Battery
[align=left]12 volts[/align]
Front Engine Accessory Drive (FEAD)
[align=left]Compact drive system with side-mounted water pump[/align]
Emission control system
[align=left]dual, heated oxygen sensors
per bank; high-volume EVAP system
[/align]
Fuel system
[align=left]High-capacity returnless with 42 lb/hr injectors[/align]
Oil system
[align=left]High-vacuum dry sump configuration;
Capacity: 12.6 qt (12.0 liters); aluminum oil tank
[/align]
Horsepower
[align=left]750 bhp @ 6300 rpm[/align]
Torque
[align=left]700 lb-ft @ 4800 RPM[/align]
Redline
[align=left]6250 rpm[/align]
umm ..
im not quoting ....
i've spent 8 ****in hours on a god damm seminar...
pretty much got drilled in my head..
the links i posted were for verification just in case you "ford experts" were doubting a ford master tech.
trust me..
i dont need some snoty nose kid to tell me what my job is about.
the whole discusion started with saleen not using ford parts...
and i proved you wrong sebba...
so quit your whining and just shut up!!
they also manufacture it specialy for al their SVT teams and ALMS series use the same block... what a shocker...
as long as theres a ford logo on the block it doesnt matter who its made for because the block is still made by ford.
Old Dec 31, 2007 | 12:38 AM
  #22
Snot nose kid... hmmm. Thats not ignorant.
Im not trying to be a ***** about this, you are.
I just asked where it said that the S7 TT was built by Ford. So far you havnt provided that.
Old Dec 31, 2007 | 12:14 PM
  #23
tidus10's Avatar
ORIGINAL: _Adrian_
umm ..
im not quoting ....
trust me..
Someone is a little sensitive....I was just copy and pasting when i seen on the site and it lined up with what you said on here so relax buddy. No one here knows that your a ford master tech or even would think that due to the fact that most people who are on here and mitsu guys/girls. I'm sure sebba just figured that ford being the company that it is would not supply saleen with parts to build a supercar without its name on it.
This got blown outta control really quick and its uncalled for...
Thanks for you enlightenment about the Ford/Saleen relationship but you could have done it without being so damn touchy about the situation.
Old Dec 31, 2007 | 01:54 PM
  #24
agreed its bull****.
Old Dec 31, 2007 | 02:01 PM
  #25
50ul }{4ck3r's Avatar
x2
Old Dec 31, 2007 | 02:02 PM
  #26
jpmontero98's Avatar
WHERE THE HELL WERE YOU?!?!?! lol
Old Dec 31, 2007 | 03:00 PM
  #27
I made that post on my iPhone ^^^ w000tt
Old Dec 31, 2007 | 08:01 PM
  #28
ba3kgt's Avatar
anyone have a vid of the s7 actually running. i couldnt find any
Old Jan 1, 2008 | 08:55 PM
  #29
tidus10's Avatar
niether could i....i dont think the damn car ever ran!! :-p
Old Jan 2, 2008 | 03:38 AM
  #30
You insane? Youtube.....
