So take a look a this
Old Sep 15, 2007 | 12:07 PM
AlZuben's Avatar
Default RE: So take a look a this
no, i got that part....but I'm curious, he could have adjusted his fuel/air mixture, right? or he could have an ethanol injection system or something as well, right?
this is the air intake for the turbo compressor? is that correct?
I'll admit, I'm not getting what you guys are all going on about. I don't see how this is causing the engine to necessarily run leaner unless this is attached in between the carburetor and the intake manifold.
Old Sep 15, 2007 | 12:15 PM
R@lli@rtR@cer's Avatar
I dont think so either like sebba said the chrome and silver bent up filter sittin on the intake on the right of the MAF should not be there if i am thinking correctly that is the vaccuum tube that runs to the intake manifold and it is a dumb move to put that filter there thats not how the intake was designed now if he would of correctly sealed it that would be ok and than ran the tube coming of the intake manifold into a filter or a catch can than it would be ok but i made that rookie mistake way back in high school yeah its n ot correct you start running your engine too lean by pushing more airflow and less fuel and like i said running lean is in terms faster but that should be done in the computer through your air/fuel ratios not just by adding filters now if i am incorrect please correct me that is how i understand it
Old Sep 15, 2007 | 01:15 PM
jpmontero98's Avatar
i had a breather filter before my maf sensor...it made my car lean and stall out....i took it out and the thing sounds great...idles a lil more than it did stock but performs great and my MPG is alot better too...the way his is is the same way i had mine.....learn mby experiance...in otherwords....u can buy the car....but that breather needs to COME OUT!!!!
Old Sep 15, 2007 | 02:32 PM
Natedogg89's Avatar
jpmontero-No im not looking to buy it, i was just looking for parts and that came up.
ralliartracer- thats the inlet for the bov dump tube....not a vaccum line.
Old Sep 15, 2007 | 02:40 PM
I see that now thats my fault
Old Sep 15, 2007 | 04:47 PM
sk8dudety's Avatar
no, the deal is that air filter is on after the maf sensor... which means the engine will be getting more air than the computer realizes... thus it won't compensate with enough fuel for the air/fuel ratio... and thus the engine will be running lean 'cause there will be more air than fuel in the mixture...
Old Sep 15, 2007 | 04:54 PM
bestwiseguy's Avatar
Not to mention that the guy is venting to atmosphere. which will also mess up his air to fuel ratio.
Old Sep 15, 2007 | 06:01 PM
I got it now my mistake for my last post its not exactly correct
Old Sep 15, 2007 | 09:07 PM
sk8dudety's Avatar
i can't imagine that car running well at all
BLAZE GS
Feb 8, 2008 09:32 PM
Russianfart
Feb 4, 2008 01:07 PM
BLAZE GS
Feb 2, 2008 10:34 PM
Ghost421
Apr 28, 2007 08:38 AM
UTREVO
Nov 14, 2006 10:56 AM
