wouldnt it be nice
Old Sep 5, 2007 | 11:07 AM
estraw's Avatar
Default wouldnt it be nice
if everything with my transmission went as planned?
im taking a manual trans principles class right now (oddly enough) and today i took apart a 5 speed ford taurus SHO FWD transmission..got it completely apart down to taking all the synchro's and everything out and put it back together in a lil under an hour.. god i hope my trans is this easy.. although i do need to pull some bearings off my input shaft.. but that shouldnt be too hard with the right tools, right??
i can only hope
Old Sep 5, 2007 | 11:14 AM
jpmontero98's Avatar
Default RE: wouldnt it be nice
it seems to me mitsu auto parts are harder to do...to do a tune up on my monty i had to remove the trhottle body
Old Sep 5, 2007 | 11:29 AM
Yeah right... good luck with that. Tell us when you find all the gears missing teeth/shredded and a nice crack in the bell housing : )
Old Sep 5, 2007 | 01:58 PM
estraw's Avatar
well i got the trans out of the car and there is no crack in the bell housingas for the gears.. i took off the view plate thingger and looked inside and all the gears that i could see look fine. no chipped teeth or anything, as far as i know the only thingsi need to replace are the bearings and the input shaft seal.. anybody know what those parts would cost??
Old Sep 5, 2007 | 02:53 PM
Not a lot would be my guess... you should be okay.
Old Sep 5, 2007 | 03:44 PM
estraw's Avatar
thats what i thought.. but my boss told me that he replaced all the bearings in his old nissan trans and it ran him 500. yikes.. i hope its not that much. o well, i just hafta get a 3.0 gpa first semester and my dad buys me the parts[8D][&:].. on the flip side, that means my car wont be running till sometime next spring[:@][:'(][>:][][X(][&o]
Old Sep 5, 2007 | 04:09 PM
dont worry it took 1 yr for mine to actually get running
Old Sep 5, 2007 | 08:00 PM
I Drive Naked's Avatar
ORIGINAL: jpmontero98
Awww boo hoo.
Lemme see you go work on my V6 Tiburon. Change spark plugs on that then you can complain.
Heres a list of parts you'll NEED.
Plugs/Wires
1 gallon Coolant
Upper intake Gasket.
TB gasket.
Rags... and LOTS of them.
hahahaha
i'm just messing with you.
But seriously, pulling a TB off is nothing.
Tearing half your motor apart is a pita.
Old Sep 5, 2007 | 09:06 PM
well i didnt want to make a list...i was simply stating its harder to do the monty than for example the red 4 cyl jeep wrangler in my garage where u can easily get to em lol
Old Sep 5, 2007 | 11:25 PM
ORIGINAL: Joshewuhh
Awww boo hoo.
Plugs/Wires
1 gallon Coolant
TB gasket.
hahahaha
th 6g72 in the 3G is the same thing. on top of that I dont wanna hear any complaints till you do a timing belt in one of those things then youll hate life lol
