Help - RVR Sports Gear - Auto Transmission
Old Apr 23, 2008 | 01:55 AM
osullivanbeara's Avatar
Default Help - RVR Sports Gear - Auto Transmission
Hi There,
New Member First Posting -
Problem:
When in "Drive" the gears sometimes slip into "Neutral" with loss of power and revving of engine. I then put into second gear, wait for gear to re-engage, then move back up to "Drive" and continue. I know this is damaging, and fear it will get worse. I have tried to avoid using the car since - only at weekends for short journeys. I have approached two garages who have told me to either dump the car, or fit a new gearbox (2000 euro !). I don't know what the problem is, but the transmission oil is a little low and very dirty - I want to change this as a first measure, but need some help.
Question: Assuming the problem is not too little oil, what are the likely causes, and what are my best options before going to a garage ? I can upload any photos you might need. What type of transmission oil should I use ?
Model; 1997 Mitsubishi RVR Sports Gear 2 Litre Petrol Auto Transmission Full-Time 4WD
Old May 25, 2008 | 01:56 PM
Pablo's Avatar
Default RE: Help - RVR Sports Gear - Auto Transmission
i own a 1998 RVR sports gear and i had the same problems, first your oil needs changing, but be sure that its the SPII or equivalent.
Secondly check the relays that controll the transmission, in my case we found condensation on the terminals.
I can't say it will work, but its worth a try.
good luck
Old Dec 20, 2013 | 01:29 AM
Kumpass Chris's Avatar
Hi there
What type of oil I should use for a diesel rvr auto gearbox ?
sander
Dec 16, 2017 11:28 PM
janarth
Other Mitsubishi Models
Apr 4, 2011 05:52 PM
manbearpig481
Apr 14, 2010 08:30 AM
Rich17
Oct 13, 2008 07:54 AM
Pablo
May 25, 2008 01:32 PM
