IAC problem, Low Idle Stall, Need Temp Fix ASAP, Thanks!
Old 06-21-2017, 04:27 PM
bgu88's Avatar
Default IAC problem, Low Idle Stall, Need Temp Fix ASAP, Thanks!
Hi guys, ive done some searching and im pretty sure my IAC has failed. Few days ago the RPMs were bouncing between 800-1200 when in Park but drove normal. Now today, when i come to a stop in any gear, the idle drops and stalls. When i start it back up, it will stall unless i give it some gas. Other than this, it drives normal. So to get it back home, I had to put it in neutral when stopped and give it some gas to keep the idle up.
Im going to clean the IAC and throttle body but need a quick temp fix to keep the idle up to drive for the next couple days. Can i adjust the throttle so its giving a little gas during startup and when driving?
Thanks guys! I really need this!
EDIT: Its a 1996 Colt 2.3L. Also no check engine light.
Fergie
06-13-2017 12:04 AM
Jeremy Baja Gladding
03-28-2015 09:47 PM
TerryB
10-18-2012 07:50 PM
torontojdm
12-16-2008 07:20 PM
torontojdm
11-27-2008 06:44 PM
Quick Reply: IAC problem, Low Idle Stall, Need Temp Fix ASAP, Thanks!
