1995 eclipse Intermittent Stalling Problem
Old May 25, 2016 | 09:47 PM
Wayne95's Avatar
Default 1995 eclipse Intermittent Stalling Problem
I have a 1995 eclipse 420a engine m/t. I'm having a problem with the car stalling while at idle and driving. Its been in the shop for a month trying to duplicate the problem while on a scanner/computer. What happens when driving is that the cluster lights come on and the car stalls. I lose only the tach and speedo but everything else stays on (fuel gauge,temp gauge & radio). The only way i can keep it running again while driving is to push in the clutch and cycle the key off and back on. Then the tach and speedo comes back and the car keeps running. The shop found the trans output speed sensor going off then kicking the ASD relay off. They changed the sensor ($300 dollars later) and I'm still having the same problem. Any help will be appreciated.
laurenvegan87
Dec 4, 2017 02:48 PM
Jaybe
Other Mitsubishi Models
Mar 6, 2016 10:09 AM
edster1
Sep 7, 2013 09:54 PM
DerbyDad03
Jun 26, 2013 09:00 PM
njcaus
Oct 13, 2008 02:07 PM
