-   PCM & Fuel Systems (https://mitsubishiforum.com/forum/pcm-fuel-systems-26/)
-   -   2000 rpm idle! (https://mitsubishiforum.com/forum/pcm-fuel-systems-26/2000-rpm-idle-31465/)
cabldawg Feb 18, 2009 11:01 AM
2000 rpm idle!
My friend's car just jumped time and bent 8 valves. I put on a rebuilt head, new timing belt, water pump, tensioner, a/c belt/alternator belt/, all new gaskets, radiator, thermostat, and gave it a little shot of freon.
The car was running perfect for me after I completed the work. I ran it through several cycles of getting it up to operating temperature and cooling back down, and took it for a test drive. Everything was perfect. She took the car and a little while later she said that the idle was jumping up to 2000 rpms. What could cause this? It should be back here in a little while, and other than checking for a vacume hose that may have slipped off I don't realy know what to look for. It is not throwing any codes.
Thank you for your help!
TheEngineer Feb 18, 2009 11:37 AM
Vaccum hoses would be the first thing i would check as well. Other than that possibly a sensor that didnt get plugged back in.
Conway3000gt Mar 6, 2009 02:01 PM
it sounds like a vacuum leak or check the tps sensor its right on the throttle body and on my 3000gt its adjustable to just try monkeying with that first since it's easy
