95 Mirage-OBD 1.5?
Old Mar 28, 2011 | 03:34 PM
dyates's Avatar
Default 95 Mirage-OBD 1.5?
Have a 95 Mirage S, 1.5. Trying to get to the DTC codes, but this appears to be an odd hybrid. The OBD1 connector is next to the fuse block, but there is only one pin inserted. An OBD2 connector is mounted under the dash on the left, but when I connect a scan tool it can't be read. Tried the trick from the chilton's book using a volt meter to "flash" the codes, but no dice.
Old Mar 30, 2011 | 08:05 AM
Tech_735's Avatar
you cannot read because you need a "MUT2" mitsubishi scanner for your year model.
jssjr5591
Sep 11, 2014 01:18 PM
Stryker
Sep 16, 2007 08:36 PM
rvelez123
May 9, 2005 07:40 PM
Xit40
Jan 21, 2005 06:04 PM
davesrave
Dec 21, 2004 04:27 PM
