Car won't start, clicking from ECU
Old May 16, 2009 | 09:15 AM
qmlhcb's Avatar
Default Car won't start, clicking from ECU
Yesterday, my 2002 Galant wouldn't start. When the lights were on, a clicking sound came from under the hood. When I checked, it was coming from the fuse box there, and a passer buy said the ECU was clicking.
A week ago, I had an entire fuel system flush/clean.
Does it sound like the ECU is shot? Can a fuel system flush do that?
Old May 16, 2009 | 12:32 PM
BrokeDad's Avatar
I hope it isn't your ECU as that is a very expensive repair. A fuel system clean/flush shouldn't have had any effect on the ECU/ECM module. I'd have the dealer or a independent import specialty shop run a computer diagnostic on it and see what codes are reported. Besides the tow bill that should cost you less than $100. I take it you have checked it simply isn't a battery that went bad. Alot of the time when a battery shorts a cell it will drain in under an hour to a level too low to start your car. If you have a volt meter handy check it and make sure it's above 12Vdc.
Old May 16, 2009 | 03:38 PM
qmlhcb's Avatar
Thanks for the reply. It ended up being both the battery and starter. I'm so thankful it wasn't the ECU.
Old Nov 10, 2020 | 09:35 AM
lovemymitsu's Avatar
Even though this is an old thread, I wanted to say thank you for sharing these tips.
I was working on a friend's Galant that would not start. Ended up doing a spark test after watching this video and I had no spark.
Took it to a local mechanic and they said it was bad ECU in my case.
mysticrythms
Mar 19, 2014 08:17 PM
christech
Jan 9, 2014 10:41 PM
sara
Sep 25, 2008 06:41 PM
edaddik
Jan 2, 2006 04:28 PM
