cheapest performance clutch available??
Old Jan 11, 2008 | 03:23 PM
newguy2007's Avatar
Default RE: cheapest performance clutch available??
i have a 1997 eclipse gst spyder. what are the measurements in mm(225?)
Old Jan 11, 2008 | 05:34 PM
Dusty Eclipse's Avatar
Lets make this easier:
http://www.istoreparts.com/clutch-mi...SD&language=en
Old Jan 11, 2008 | 05:46 PM
Not quite... try a street disc
Old Jan 11, 2008 | 06:19 PM
Good call Seb, didnt read that part.
Old Jan 12, 2008 | 11:51 AM
there are plenty of places to buy this clutch
www.slowboyracing.com
www.dsmparts.com
www.cimotorsports.com
www.roadraceengineering.com
take your pick. Like sebba said, only get the street disc. You dont need a puck clutch
Old Jan 12, 2008 | 01:11 PM
Unless you want a chiropractor bill
Old Jan 13, 2008 | 12:01 AM
ComposeEvo's Avatar
you can also just buy the clutch pad by it self. Since you are planning on spending less money, use the stock pressure plate and T.O bearing. Just replace the actual clutch pad. It's just ask effective, rides alot smoother then act pressure plate, and a hell of alot cheaper. It's like 80 bucks for just the pad depending on where you get it. Now if the pressure plate is heat checked and so is the T.O bearing or flywheel, either have them resurfaced which is cheap, or go to the junk yard and get one in decent condition.
I tell all my customers with hondas to this trick. Saves them alot of money and time.
Gus
Old Jan 13, 2008 | 10:13 AM
ORIGINAL: Sebba
LMAO
Colt-Speed Ca
Dec 31, 2011 03:04 PM
Colt-Speed Ca
Jan 24, 2011 11:26 AM
Colt-Speed Ca
Jan 23, 2011 10:29 AM
Colt-Speed Ca
Jan 5, 2011 09:42 AM
maclawa
Jan 1, 2006 02:54 PM
