-   PCM & Fuel Systems (https://mitsubishiforum.com/forum/pcm-fuel-systems-26/)
-   -   Clutch Hard-line Replacement (https://mitsubishiforum.com/forum/pcm-fuel-systems-26/clutch-hard-line-replacement-44087/)
Nike619 Mar 9, 2013 02:55 AM
Hey guys, Alright I'll get right to the point.
After using the search function I was unable to find the answer to my question.
I have a 96' GS, 5 speed. And a few days ago I had ran out of clutch fluid ( Forgot to check it like an idiot ) and immediately went into problem solver mode. Master: Nope
Slave: Yes.
Replaced the slave without a problem ( **** the placement on that thing ). And when bleeding, I discovered my problem wasn't the slave cylinder but however, the bolt on the line into the slave itself. I have it tightened as much as it can be, but nonetheless the line is pretty rusted and I'm afraid it's only going to get worse.
My question is, where can I find a new line? Is there a chance of getting an OEM/ Aftermarket hardline, or is it going to have to be manually made?
Thanks for reading.
