Coil?
Old Dec 14, 2006 | 03:32 PM
GrayGST's Avatar
Default Coil?
alright since i got the car i have been told that when i go wide open throttle it smokes black. when i do that it sometimes bucks then goes, well some times lately i hear a loud clicking. kinda like a valve, but its a little different and its directly on top of the coil pack. so my question has two parts. one, has anyone else had this problem, and two, i have a coild pack off of a 95 gst, i have a 97 gst. they should be a direct swap with no problems right? thanks for your help.
Old Dec 14, 2006 | 03:35 PM
Default RE: Coil?
Yes they would swap no problems.. but why would you do that?
Also, what mods are done to the car?
Old Dec 14, 2006 | 03:41 PM
Default RE: Coil?
black smoke is just burning oil. It probably does it when you let off the gas after WOT. And the sputtering is probably either bad spark plugs or wires. Could you get a picture of your engine bay
Old Dec 14, 2006 | 03:48 PM
GrayGST's Avatar
Default RE: Coil?
blue smoke is burning oil, black smoke is burning rich and it does it when i start wide open, throttle. my mods are 14b, front mount, hard pipes, cold air, lightwieght flywheel. but it did it even when the car was stock. but what gets me the most is why it ticks so loud almost like it is arching out. but since i already have a coil pack from a 95 gst all i needed is some one to give me a second answer on if they are able to swap
Default RE: Coil?
black smoke is normal... are u hoping to find a vented BOV? lol
Old Dec 14, 2006 | 03:50 PM
Default RE: Coil?
i already answered you. Also, please post a pic of you rengine bay. I take it you have a MBC.. what is it set to? What BOV are you running? Is it recirculated?
Old Dec 14, 2006 | 03:52 PM
GrayGST's Avatar
Default RE: Coil?
yes i have a mbc, its set to 15lbs for now, until i do fuel upgrades, it is a greddy rs and its recirculated.
Old Dec 14, 2006 | 03:56 PM
Default RE: Coil?
damn... im outa ideas
Wait, what plugs and wires do you use?
Old Dec 14, 2006 | 04:00 PM
Default RE: Coil?
the ticking it probably lifter tick. I would check for a boost leak.
Old Dec 14, 2006 | 04:02 PM
Default RE: Coil?
^^ that too
