correct injectors??
Old Mar 9, 2010 | 12:31 PM
jhywrd03's Avatar
Default correct injectors??
I've been searching all of last night and all of this morning and I can't seem to find it so i'll ask. I'm wondering if the 450cc injectors from a 1990 eagle tsi would be right for the 14b i'm putting on my 2000 eclipse gs. I am using the turbo from that talon and the manifold bolts up. I'm just wondering if i can use those injectors. If anyone could point me in the right direction that would be much help.
Old Mar 9, 2010 | 09:39 PM
dsm1990gsx's Avatar
Your gonna need something to control the injectors such as an apexi safc. How much boost are you gonna run?
Old Mar 10, 2010 | 09:22 AM
jhywrd03's Avatar
Thats what i've been reading. Because they are low impedance. right? I know I will also need to replace the injector plugs ( or clips/wires, not sure the correct name) so it won't be too much more trouble to tie in the safc. I'm going to be running around 7-9 psi. I haven't found anything that is really clear on size of fuel pump and injectors I will need for that range of boost on my car.
Old Mar 13, 2010 | 07:46 PM
why not stick with the stock injectors. They are fine for a 14b which isnt much of an upgrade
Old Mar 14, 2010 | 11:07 AM
jhywrd03's Avatar
Putting a turbo on a car isn't much of an upgrade? I know its not a huge turbo but it is it is quite an upgrade to turbo a non turbo car. I will keep looking. I'm getting closer to finding the anwers I need. Thanks for the feedback though. The more the better.
bigguy6f4
1st Generation
Jul 14, 2007 02:03 AM
bigguy6f4
1st Generation
Jul 3, 2007 09:52 AM
50ul }{4ck3r
Feb 18, 2007 07:56 PM
50ul }{4ck3r
Feb 18, 2007 04:02 PM
DeathCabForCutie
Mar 16, 2006 11:56 PM
