Fuel Injector Clog?
Old Jun 15, 2006 | 04:27 PM
silveira03's Avatar
Default Fuel Injector Clog?
I used STP complete fuel system cleaner on my 2000 Mitsubishi Eclipse GS (4 cyl, automatic/tiptronic). Ever since I used up that whole take of gas with the fuel cleaner, it feels like we the engine isn't getting enough gas when the engine is idling at or below 1000 RPM's, and the engine will die (and now the "service engine soon" light is on all the time). I think what happened is that the fuel system cleaner knocked some gunk loose and into the fuel injector, which is restricting gas flow to the engine. Does that sound right? What do you recommend? Should I attempt using MORE fuel system cleaner/fuel injection cleaner, or should I attempt to remove the fuel injector to see if it needs cleaning? If so, how do I go about locating/removing it? I made an appointment for a diagnostic at the Mitsubishi dealership, but it's going to be expensive just for the diagnostic, and I would rather just fix it myself. Let me know what you guys think.
Thanks!
Old Jun 15, 2006 | 09:34 PM
Default RE: Fuel Injector Clog?
It could be anything really. It sounds like one of the plugs isnt fireing right. I would change your plugs and wires and see if that works. Personally i dont use any kind of fuel or oil aditive at all... but thats just me
Old Jun 16, 2006 | 10:18 AM
i doubt that he got a plug problem from fuel cleaner . I know thats not what your saying but he said he started the problem when he used the stuff. It has to be a fuel system problem. If you want to get the code run on that car for free then go to autozone. They will plug it in and tell you what is comming up. That will at least give you a hint as to where to start with it. Rather than pay the dealer 70 bucks for a stupid diagnostic. Then let us know what the code is
Old Jun 16, 2006 | 12:25 PM
hmmm... it could be a coinsidence. I bet you it will return the code for a misfire. Im not saying that injector cleaner caused any kind of plug problem... but it still could be the problem
Old Jun 16, 2006 | 01:14 PM
silveira03's Avatar
Wow, I didn't know that Autozone did that. I'll take it in tomorrow morning to see what comes up. What's going on doesnt really sound like a missfire, and I checked the plugs a few weekends ago before I drove my car out of town for the weekend. I'll come back with a code later, and let you guys know what's going on. And if anyone thinks of anything else in the meantime, please let me know!
Old Jun 16, 2006 | 02:58 PM
Well it could give a misfire code and still be a fuel problem if the engine is getting air but not enough fuel to compensate
Old Jun 16, 2006 | 06:56 PM
Exactly... but it could also not be firing right.
Old Jun 17, 2006 | 02:40 AM
i guess only time will tell
Old Jun 17, 2006 | 10:27 AM
Agreed
Just because the plugs look ok does not always mean they are sparking right. Could be the coil pack or a spark wire
96tsi
Nov 2, 2006 11:25 AM
jimhood82
Sep 12, 2006 01:26 PM
burnmyeyes
Jun 27, 2006 11:16 PM
dennistan80
Jul 19, 2005 09:42 PM
scone
Jul 3, 2005 10:47 AM
