head replaced and car wont start
Old Oct 1, 2007 | 09:50 PM
Juggalosfaygo69's Avatar
Default head replaced and car wont start
my friend has a 96 eclipse rs thehead blew. got a new head for it and now it wont start. it turns over and cranks but wont start his dad checked the signal to cam sensor and its good the coil is recieving signal but not sending signal tried to check signal to crank sensor but cant figure it out cuz its in a hard spot to get to. they arent sure if its that sensor that is bad or the pcm.his dad said its getting fueltoo.anyone have any suggestions to what else it may be? need to figure it out quick cuz my friend is goin into the national guard soon and he wants it running before he goes. any info would be great thanks!
Old Oct 2, 2007 | 06:31 AM
Default RE: head replaced and car wont start
its most likely your timing is not correct. Fix that and you should be good. Just check the timing marks
Old Oct 2, 2007 | 11:28 AM
ya his dad siad the timing should be good....but yesterday he said it might be 180 degrees backwards
Old Oct 2, 2007 | 11:50 AM
Well that would mean a perfect piston-valve collision.
Old Oct 2, 2007 | 12:12 PM
well then its not that cuz it doesnt make any knocking sounds what so ever....he thinks the pcm might be bad....i also read the post on the asd and told him to check that. he's read the entire hanes manuel cover to cover and hasnt been able to figure it out. this has been like a 3 month problem and is getting very frustrating!
Old Oct 2, 2007 | 02:10 PM
You wouldnt really hear anything. Trust me. If the timing is reversed... THATS it.
Is it reversed or not?
Old Oct 2, 2007 | 05:07 PM
not sure wont find out until we go back out there. ill find out and and post back
Old Oct 3, 2007 | 06:06 AM
ORIGINAL: Sebba
sebba they wont have collided already from trying to start the car. All he should need to do is fix the timing and then it will start right up
Old Oct 3, 2007 | 07:20 AM
Not with a 180 degree difference
Old Oct 12, 2007 | 11:14 AM
well we got a new crank sensor went to put it in and it was the wrong one the plugs dont match up the guy at the parts store gave us one for a 97 i thought it would be the same but apparently not
