MDS vs MAP
Old Jun 11, 2008 | 08:41 PM
itsnt4me's Avatar
Default MDS vs MAP
Greeting all,
Any experts out there know if the MDS (manifold differential sensor) has the same functionality as a MAP sensor (manifold airflow sensor)?
Thanks
Old Jun 14, 2008 | 05:36 PM
HandyPal's Avatar
Default RE: MDS vs MAP
Same idea of giving ECU the information needed to calculate fuel/air ratio. Pretty similar technology.
AirMass flow sensors are based on a heated wire of a certain resistance that is changed with air flow by cooling the wire and hence giving different voltage output. Map sensor senses vacuum in the manifold which is function of air flow. Differential is comparing pressure/vacuum before and after throttle, thus givinginformation on how much air is flowing through at the moment (equal or almost equal pressure means fully open throttle). Hope it answered your questions.
Old Jun 14, 2008 | 06:07 PM
itsnt4me's Avatar
Thanks for the reply. That does answer my question. I have a follow up. Since you understand the MDS circuit, would it be possible to use it to lean and richen out the mixture by varying the resistance from the output from the sensor to the ECU? For instance inserting a pot inline between the MDS sensor output and the ECU? Thanks.
99clipsgst
May 3, 2012 12:49 PM
TX97GST
Nov 8, 2006 03:16 PM
00GalantMan
Sep 1, 2006 03:06 PM
hoosierdaddy_87
Jun 19, 2006 02:27 PM
Shadowplane676
Apr 19, 2006 11:45 AM
