Motor mount
Old Jun 25, 2008 | 08:05 AM
Jre56's Avatar
Default Motor mount
How diffilcult is it to change the top,driver side motor mount on my 1998 GST eclipse.The rubber is chewed up.
Old Jun 25, 2008 | 01:31 PM
Default RE: Motor mount
Depends what equipment you have. Engine hoist? Jack?
Old Jun 25, 2008 | 05:22 PM
Jre56's Avatar
I have a floor jack.
Old Jun 25, 2008 | 06:02 PM
Its going to be hard. You need to put the jack under the engine, remove the mount bolts, raise it up a little.. and change it.
Old Jun 25, 2008 | 06:48 PM
Jre56's Avatar
Is there anywhere I can buy the inserts and have them pressed in instead of replacing the entire mount?
Old Jun 25, 2008 | 08:44 PM
Yeah thats what I meant, my bad.
Old Jun 25, 2008 | 10:06 PM
Jre56's Avatar
Ok, thanks for your help! Do you know if any of the newer model's(2004-2007) use the same mount? Maybe I can go to a junkyard and buy one that's already off.
Old Jun 25, 2008 | 11:18 PM
No
Old Jul 2, 2008 | 07:15 AM
sk8dudety's Avatar
yea you can definitely get the new inserts put in, but if i were you i'd replace all four of 'em while it was up in the air, that way instead of having only one urethane piece and having it be all awkward it'd feel a lot better for you. besides you have to buy it all in a kit anyway lol
Ryan
Jul 28, 2007 09:02 PM
Gstfat
Jun 11, 2007 10:10 PM
shiznit013
Oct 11, 2005 12:45 AM
EclipseGSRoadRacer
Oct 17, 2004 03:36 PM
1spyder2nv
Aug 12, 2004 09:54 PM
