question about the SAFC II
Old Oct 3, 2007 | 02:22 PM
Default RE: question about the SAFC II
It doenst actually MEAN full boost. I could make it say vacume is full boost if i wanted
Old Oct 3, 2007 | 05:26 PM
96tsi's Avatar
I found another dyno sheet. and this time it hit 15.8 pounds and the afr was 11.7
Old Oct 3, 2007 | 05:27 PM
Nothing wrong with that ratio.
Old Oct 3, 2007 | 05:33 PM
96tsi's Avatar
what do you mean about vacuum? on my sheet it says the rpm's and hp and tq, and then on the last lineit says boost psi. it is in increments of 20 rpm's. starts at 2500 and goes to 6500 rpm. and it says all the specs for each rpm that is recorded.
Old Oct 3, 2007 | 05:42 PM
Lol ignore it i was being a smart ***
Old Oct 3, 2007 | 05:47 PM
96tsi's Avatar
ok. so if i build the bottom end do you think the car would be able to run ok if the afc can control it as well as it has at 16 pounds? I was thinking of maybe pusing 25-30 pounds but I don't know if that is possible with the safc II.
Old Oct 3, 2007 | 05:48 PM
Your running all this on a stock bottom end?
This car needs DSMLink.
Old Oct 3, 2007 | 05:57 PM
96tsi's Avatar
ok
Old Oct 3, 2007 | 05:58 PM
96tsi's Avatar
thanks guys
92_laser
1st Generation
Jan 22, 2006 03:15 PM
antlip
Dec 27, 2005 08:44 PM
chrispimpryan86
Dec 8, 2005 12:26 AM
16psi eclipse
Oct 1, 2005 01:51 PM
1320a
Mar 6, 2005 10:00 PM
