RISING RATE FUEL REGULATOR
Old May 23, 2008 | 02:25 AM
kakarot42's Avatar
Default RISING RATE FUEL REGULATOR
Can any one please tell me wat psi i sould be running???. Im just about to install a rising rate fpr but b4 i do i would like to no wat psi i sould be running i own a 1998 ce lancer with a good old 4g15 sohc ive put a pod filter on her and a set off extractors with a 2 1/4 exhaust from cat back should i be around a bout the 25psi range on idel???
any help would b apprecated i did the good old google but couldnt find any thin
Old May 23, 2008 | 11:44 AM
Default RE: RISING RATE FUEL REGULATOR
First off, learn how to use punctuation, and work on your spelling.
For that, I would suggest about 35psi at idle.I don't know what you are hoping to achieve by doing that. Unless your car won't idle correctly, you shouldn't be messing with it.
Old May 23, 2008 | 06:53 PM
kakarot42's Avatar
Thank you very much 4 your reply not so much on the grilling im guessing you understood the msg so it cant be tat bad....
ivebeen on the rpw site and they recon the first thing you should do to the lancer is put a rising rate on her to get rid of the flat spot and trust me it has a huge flat spot... im just looking to get my acceleration back thanks champ 4 the HEPL????? lol
Old May 23, 2008 | 06:55 PM
That is down to the fuel map, raising the pressure on an FPR won't do much.
Unless you have down syndrome, why misspell stuff? It's really not that hard.
Old May 23, 2008 | 07:23 PM
kakarot42's Avatar
funny you menchane tat.. down syndrome thanks buddy i fill really great now its bad anuff couping with it on a day to day bases let alone from a computer
Old May 23, 2008 | 07:27 PM
That actually made me laugh. I guess I will give you that one.
Old May 23, 2008 | 07:39 PM
kakarot42's Avatar
glad to assist in brightening up ya daythanks for the help champ...
p.s love the pick on your posts thats my dream car... welll g2g get ready playing lax
shortly thanksfor the grilling looking forward to hearing more abuse from ya sebba keep up the good work[:-]
Old May 23, 2008 | 07:58 PM
That's not abuse in the slightest.
Bill H
Feb 21, 2013 11:33 AM
Sammy134
Feb 15, 2013 09:57 PM
surfcandy
Oct 17, 2009 08:54 PM
bdhunter
Nov 29, 2006 09:34 PM
rartoutlander
Oct 18, 2004 04:04 PM
