videohornet
my 2001 eclipse quit running, broke timing belt.which bent 3 intake valve,replaced belt & valve.cannot get fuel pump and injectors to fire. was told the ecu-mr530103 was bad.what ive read is this is the airbag ecu. will this cause the fuel pump and injectors not to fire?
(was told the ecu-mr530103 was bad) who told you this ???
took ecu to mitsubishi shop had it checked , they said it was dead
did you also have the engine ecu checked ????
