videohornet
Old Aug 27, 2012 | 05:01 PM
videohornet's Avatar
Unhappy videohornet
my 2001 eclipse quit running, broke timing belt.which bent 3 intake valve,replaced belt & valve.cannot get fuel pump and injectors to fire. was told the ecu-mr530103 was bad.what ive read is this is the airbag ecu. will this cause the fuel pump and injectors not to fire?
Old Aug 29, 2012 | 09:22 AM
mxmikie's Avatar
(was told the ecu-mr530103 was bad) who told you this ???
Old Aug 30, 2012 | 04:54 PM
took ecu to mitsubishi shop had it checked , they said it was dead
Old Aug 31, 2012 | 06:03 PM
mxmikie's Avatar
did you also have the engine ecu checked ????
