baggin
Old May 6, 2006 | 08:17 PM
mightymax582's Avatar
Default baggin
Got a 91 mighty max and i am looking to bag it but i dont no to much about bags at all. I do no all the parts i need. What i dont no is about the front end. What all is involved in the front besides cutting the fender wells all out and everything. Any tips on what i need to notch or anything else usefull would be nice.
Old May 15, 2006 | 12:26 AM
bennyt's Avatar
Default RE: baggin
whats up ,its really according to what size wheel you are runnig if you have to cut the fender wells out .you do have to cut the spring purch out or if it has torsion bars you have to cut all that out where the bump stop is mounted and weld you a upper and lower bag bracket in and then install you bags and install shock relocators that allows you to run a shock so that you want look llike a rocky horse coming down the road thats about it for the front its not really that hard hit me back i might be able to guide you threw it
