control arms?
Old Jan 5, 2008 | 06:17 PM
rses's Avatar
Default control arms?
i bought a coilover for my 02 LANCER to drop mine (not too low)...and one of my buddies of mine lowered his ol school 240 and had to put control arms in order to adjust his camber...
do i have to get control arms for mine too?
Old Jan 5, 2008 | 06:45 PM
Default RE: control arms?
you dont need arms you just need a camber adjustment kit however you only need it if you plan on dropping it more than 1.5"
Old Jan 5, 2008 | 06:49 PM
rses's Avatar
camber adjustment kit is a bolt, correct?
Old Jan 5, 2008 | 07:24 PM
well sort of. The front i believe are more like a separate small arm and the rears are kinda like a bracket. But once again you dont necessarily need them. What i would do is put it to where you want to lower it and if you feel that you have too much neg. camber (tire wear excessive on one side of tire) then get the kit. But normally its not till after 1.5-2" that you will really start to see some bad tire wear
Old Oct 16, 2008 | 09:39 PM
ccamaro98's Avatar
this website seriously has everything for a mitsubishi
northface
Jul 18, 2010 08:44 PM
Mike4x4
May 20, 2010 06:19 AM
jtherrien69
Aug 17, 2009 07:29 PM
irankzz
Apr 2, 2009 10:55 PM
97redEclipse0010
Apr 25, 2006 11:42 PM
