Front sway bar confusion... HELP!!!
Old Sep 26, 2009 | 05:05 PM
lillben07's Avatar
Default Front sway bar confusion... HELP!!!
So, I did a bunch of research about upgrading my sway bars and on different companies that offer F+R kits. I decided to go with the Suspension Techniques kit and received it yesterday, began installing it today. The rear bar went in no problem, direct fit. The front on the other hand, has me confused and frustrated beyond my limit. I can't figure out if they sent me the wrong one, or if there is a conversion/fabrication that I need to do. The bar that I got is a lot different from the stock one that was on my car and came with the end link kits while my stock one uses the ball joint links. I really need help figuring this one out! I am also going to email ST to see what they say. I am including pics to help you guys help me. Thanks!!!!!!
Attached Thumbnails Front sway bar confusion... HELP!!!-dscn1294.jpg   Front sway bar confusion... HELP!!!-dscn1295.jpg   Front sway bar confusion... HELP!!!-dscn1297.jpg   Front sway bar confusion... HELP!!!-dscn1298.jpg   Front sway bar confusion... HELP!!!-dscn1301.jpg
Swamp Gas
Oct 4, 2009 01:14 PM
frs_man
Feb 5, 2009 11:34 PM
eclipseGS98
Aug 20, 2007 07:16 AM
Atownprepy99
Oct 12, 2005 05:10 PM
gforceauto
Mar 5, 2005 12:27 AM
