How to tilt.....
Old Apr 9, 2007 | 10:21 PM
dirtracineclispe's Avatar
Default How to tilt.....
the top of the right front tire in?? I have a 1G eclipse GS, and want the right front tire tilted in.I purchased a special bolt that you can put in there, but something with suspension does not allow my tire to tilt at all. Any ideas??
Old Apr 10, 2007 | 01:46 AM
Default RE: How to tilt.....
you need a camber kit
Old Apr 10, 2007 | 09:50 AM
Where can I get one of those for a 91 Eclipse GS?
Old Apr 10, 2007 | 09:58 AM
well the bolt thing you have might be the camber adjustment. Maybe your not doing something right. But they should look something like these
http://www.dsmparts.com/customer/home.php?cat=99
or also you can look here in the suspension area
http://www.4g63.cimotorsports.net/
Old Apr 10, 2007 | 10:13 AM
Dusty Eclipse's Avatar
Yea, apparently you need a camber kit for all Eclipses... Do I needa kit to install my Tein S-Techs, TE?
Old Apr 10, 2007 | 10:17 AM
well you usually only need it if you start to lower your car too much and you will end up with some neg. camber, so youd need the kit to adjust it. I usually say anything more than about a 1.5-1.2" drop then you start to need it.
Old Apr 10, 2007 | 10:22 AM
I should be alright then, I figure. Im looking at like 1.25-1.75max. Though the rear end on my 3G currently looks sorta toe out...
Old Apr 10, 2007 | 07:05 PM
That is what the bolts look like. What could I be doing wrong? Following the directions, but will only let me tire tilt in very very minimul. Does lowering the car have anything to do with this?? I am not lowering anything.
