lower
Old May 7, 2007 | 07:17 PM
spyder4g63t's Avatar
Default lower
i have arospeed springs i think a 2 inch drop with gr2 shocks now i really want a lower setting but i cant seem to find springs with a big drop should i just get coilovers i would like atleast a 2 1/4 drop also what brand and if there adjustable...to lower and raise .....dsm has the most aggressive drop ever seeen by the human eye..yes its that serious..haha
Old May 7, 2007 | 09:24 PM
Default RE: lower
all coilovers are adjustable. They are expensive though. Usually for around $900+ and just stick to name brand like tien, or megan
Old May 8, 2007 | 07:00 PM
Default RE: lower
do they all differ as in height like sum go lower then others..only thing about coil overs is the anoying sounds they make but i guess its worth it
Old Jun 3, 2007 | 10:27 PM
razvan76's Avatar
Default RE: lower
You can cut a coil of you dropped springs and that will give you atleast 1 more inch of drop and the ride wont be diffrent. It's ok to cut drop coils but not so good on stock ones. I did on mine and have had them that way since 2000. Ride is good.
Old Jun 4, 2007 | 10:21 AM
Dusty Eclipse's Avatar
Default RE: lower
Thatsa BIG drop in any case... are you sure you really want to go that low? You wont clear most speed bumps...
WickedxCurves
May 8, 2006 03:13 PM
sasjod
Apr 7, 2005 09:50 PM
Gregory
Dec 19, 2004 06:29 AM
Customshiftboot
Jul 29, 2004 05:17 PM
1rippinGT
May 3, 2004 01:46 PM
