lowering
Old Jan 16, 2008 | 03:28 PM
rses's Avatar
Default lowering
i am gon' lower my car this Friday Night w/ a coilover.
i heard that the car only can lower up to 1.5 and if i wanna drop lower than 1.5 i'll need arm (control the tires)
is this true?
Old Jan 16, 2008 | 04:24 PM
Default RE: lowering
well judging by the question im guessing all you have is the coil inserts. I must warn you if thats what you have you will most likely have a bad ride quality from it, and it may end up doing damage to the struts.
But what you are gonna need is a camber kit, otherwise you will notice negative camber in the tires and you will have an uneven wear in them were the edges of the tire will start to wear out
Old Jan 17, 2008 | 12:58 PM
rses's Avatar
where can i get the camber kit? how much is it around? is it a bolt? can i get it at any auto store?
Old Jan 17, 2008 | 05:16 PM
Rob's Avatar
Rob
Before you waste your time and money, are they e-bay junk coilvers, or real coilovers? Expect to pay 1k+ for real ones.
ray@ipp
Mar 21, 2005 03:11 AM
96gsxpimpin
Jan 9, 2005 12:33 AM
m3kgt_99
Nov 24, 2004 08:31 PM
unplugged_nate
Jun 30, 2004 02:43 PM
Eric Cannon
Apr 9, 2004 02:31 AM
