need help
Old Apr 15, 2008 | 01:18 PM
95GS's Avatar
Default need help
how you guys doing? I just got a 95 eclipse GS for 250 bucks, and its got an issue. The rear end is making a knocking noise when i go over any bumps and when I get up to around 60, the rear end sways pretty bad. I got up under the car and checked everything out and i can move the sway bar around with my hand. Anybody have any ideas as to what could be the problem?
Old Apr 15, 2008 | 04:35 PM
Default RE: need help
its your sway bar end bushings. They are only like 10-20 at any parts store and very easy to change out. But i would check the ends first before you buy them. If its not those then its possible that it make be one of the joints on the control arm
Old Apr 15, 2008 | 09:50 PM
95GS's Avatar
thanks! What would be the best way to check them, just look at them and see if they're cracking and whatnot?
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
