Rear end alignment
Old Mar 23, 2008 | 11:29 AM
Shadow_USMC's Avatar
Default Rear end alignment
I have a 2005 Galant. Recently I fishtailed on the freeway and hit the center divider with my left rear side. My tire is now angled at an inward position. I changed the wheels just in case the rim was bent but the new wheels are angled in the same direction like this \ I found that a metal bar that comes from the rear of the car and connects to where my calipers mount was bent. I straitened it out but when I lowered my car the wheel was still angled in the same direction but not as bad. I jacked it back up and took another look but everything is in tact. I was reading around and was wondering if it is possible that my shock is broken and I can't tell and that is what causing my wheel to pull in on the bottom. I am new to suspension and this is my first Mitsubishi.
Thanks in advance to anyone that can help me out with this issue.
Old Mar 24, 2008 | 01:06 PM
dsm1990gsx's Avatar
Default RE: Rear end alignment
If any parts are bent or broken I would replace them instead of trying to fix it. And you said you lowered your car, how much? Youjust might need a camber kit.
Tpaul
May 21, 2013 02:38 AM
sn22
Apr 9, 2011 09:31 AM
Jackpot01
Dec 23, 2006 04:17 AM
Polonez
Nov 18, 2005 04:36 PM
toneloksta
Aug 27, 2005 03:17 AM
