Specs ?
Old May 17, 2006 | 05:47 AM
Qwakdaddy's Avatar
Default Specs ?
Hey Ya'll...new to this forum, and I'm looking for info and help. I found a 2003 Outlander in local wreckingyard , its basiclly stripped but there are some parts on it that have very little wear and tear. Specfically, chassis and suspension. Could anyone tell me what the spring rates and lenghts (struts) are for the vehicle? It was an AWD before its demise. I understand it shares the lancer platform, at least that what I think I heard. Not that that matters to me. I'm tring to do a inexpensive upgrade for my GVR4, thats why I'm looking... Thanks, Scott
What, no spel check?[]
Old May 17, 2006 | 12:45 PM
dirtwagon's Avatar
Default RE: Specs ?
I'm not familiar with your vehicle, but something to think about is the weight of the Outlander...around 3400lbs in AWD format. The AWD Outlander also sits with about 8" of ground clearance. The Outlander is based on the Lancer platform, but I don't believe it shares very much with the Lancer due to the drastically different purposes and sizes of the vehicles. Even the ECU is programmed differently on the same 2.4 Lancer and Outlander engines. Aside from sharing the mechanical aspects of the 2.4 engine, I wouldn't plan and there being many more similar parts. Hope this helps a little.
SmokeShow
Apr 18, 2006 12:32 AM
rico
1st Generation
Feb 16, 2006 03:28 PM
tkrahel6
Jan 17, 2006 06:25 PM
bobdilts
Nov 14, 2005 02:44 AM
JDMVR43000
Jul 18, 2005 07:33 PM
