?!Sway Bar Broken!?
Old Nov 8, 2007 | 01:38 PM
yellalancer02oz's Avatar
Default ?!Sway Bar Broken!?
hey, when i got my 02 lancer oz's clutch fixed, my mechanic said that when the car was lifted he noticed that my sway bar was broken on both ends, how bad is that for my car, and how soon should i get that fixed. also. am i losing any preformance ability with it being broken?? thanks
Old Nov 8, 2007 | 04:55 PM
sk8dudety's Avatar
Default RE: ?!Sway Bar Broken!?
well that'll affect the way the car handles... is it completely busted off? sounds to me like you need to upgrade! go ahead and get an aftermarket performance one
Old Nov 8, 2007 | 05:38 PM
idk i didnt see it but its still on there its just broken. how much difference is there between an aftermarket sway bar vs. a replacement one??
Old Nov 8, 2007 | 06:03 PM
sk8dudety's Avatar
it'll be a lot stiffer in the aspect of cornering... you'll be able to cut corners at a higher speed (not sure if that matters to you)... it just stiffens up ur suspension.
Old Nov 8, 2007 | 08:01 PM
dsm1990gsx's Avatar
Well your gonna have more body roll if you dont fix it, and did themechanic mean the links itself or the actual sway bar?
Old Nov 9, 2007 | 07:59 AM
To me it sounds like all hes talking about is the links. Those are really cheap and easy to replace. Its just a bolt with a couple of washers and bushings
Old Nov 9, 2007 | 05:00 PM
jpmontero98's Avatar
or bvuy an after market onebetter handling....
Old Nov 9, 2007 | 06:45 PM
dsm1990gsx's Avatar
ORIGINAL: TheEngineer
Thats what I figured too. Aftermarket links wont really do much for handling, upgrading the sway bar would.
Old Nov 10, 2007 | 04:34 PM
well thats basically what i meant[:-]
AvantGarde02
Apr 4, 2007 05:21 PM
Maximus99
Feb 22, 2006 01:51 AM
t4_gsx
Dec 18, 2005 08:45 PM
Atownprepy99
Oct 12, 2005 05:10 PM
gforceauto
Mar 5, 2005 12:27 AM
