wierd rear suspension fishtailing!
Hello all,
i'm having this problem on my mitsubishi galant 03 that when i hit bumps on the road, the rear of the car sways! it also fishtails when the road is slightly wet. I hope its not a big issue any opinions welcome |
RE: wierd rear suspension fishtailing!
Check your rear sway bar end links. I bet one of them is broken. They will be behind the wheel under the car. And the sway bar is a small bar that runs from one side of the car to the other.
update
i went to one guy who installed a camber kit on the rear tire. the car isnt fishtailing anymore but you do feel a pull at times,
in the suspension the only thing they could find was the front right control arm was moving about a bit in its place, where it contacts the wheel |
