wierd rear suspension fishtailing!
Old Feb 12, 2009 | 07:13 PM
talhauy's Avatar
Default wierd rear suspension fishtailing!
Hello all,
i'm having this problem on my mitsubishi galant 03 that when i hit bumps on the road, the rear of the car sways! it also fishtails when the road is slightly wet. I hope its not a big issue
any opinions welcome
Old Feb 12, 2009 | 07:44 PM
Default RE: wierd rear suspension fishtailing!
Check your rear sway bar end links. I bet one of them is broken. They will be behind the wheel under the car. And the sway bar is a small bar that runs from one side of the car to the other.
Old Feb 26, 2009 | 11:01 PM
talhauy's Avatar
Default update
i went to one guy who installed a camber kit on the rear tire. the car isnt fishtailing anymore but you do feel a pull at times,
in the suspension the only thing they could find was the front right control arm was moving about a bit in its place, where it contacts the wheel
rszalai
Feb 12, 2013 12:27 PM
wulls1313
Aug 21, 2005 12:54 PM
Atownprepy99
Aug 20, 2005 01:00 AM
KillerEclipse
Apr 20, 2005 12:14 AM
Subiman91
Oct 5, 2004 05:41 PM
