Shiny Bits in the Pan
Old May 5, 2026 | 03:27 PM
Naeos_Valkarian's Avatar
Default Shiny Bits in the Pan
I need some advice/opinions here. I parked my montero over a year ago due to feeling a new vibration when accelerating, hearing a new but very faint knocking sound, and the engine sounding...hmm...louder in the cab(not an exhaust leak). I was convinced the engine was on it's way out but I've been known to overexaggerate when I suspect there's a new symptom. I changed the oil about six months ago or so and found some shiny bits in the pan. Well, good times never last and now I need to daily this montero sport again. Give it to me straight up. Is this engine toast? If it is, I may be able to replace the rod and main bearings with the engine still in the vehicle but it will not be an easy task and finding a place to do it will be tricky. (I live in an apartment) I've gotten quotes from mechanics anywhere from 3K to 6K for an engine replacement. Nobody wants to repair anymore, just replace.
I've spoilered the images due to their size. Also, the oil seems milky because it was sitting for about a year before I did this oil change and collected some condensation.
Spoiler
Spoiler
Spoiler
Old May 5, 2026 | 10:41 PM
You're correct, those are likely bits from the rod bearings. The good thing - there are very few of them, which means it is in a very early stages of failure. That means it is very likely that you can get away with just replacing the bearings to get back on the road.
You're right - nobody wants to repair things any more. It's sad but true.
Old May 6, 2026 | 06:33 PM
That's what I was afraid of. Well, I guess I'm gonna do the ole tried and true "wait till management isn't at the storage yard on Sunday and work on it in secret" routine. Wish me luck. I'll upload pictures of the bearings when I fish them out.
Old May 6, 2026 | 08:09 PM
Decided to go with King Engine Bearings. Heard good things about them.
Old Today | 12:13 AM
The work is done, replaced the rod bearings yesterday. Only took me 12 hours to do, mostly because I kept forgetting stuff and had to run out and get them. Probably would have taken me 8-9 hours otherwise. Didn't even need to jack up the front end either, I was surprised. Anyways, it seems to have been a success! Startup was smooth as butter, no rod knock, engine runs like a top, and my lifter tick is gone as well. I couldn't give it a proper break in yet as it's not registered so I can't drive it. I'll upload some pictures of the bearings as soon as I can, I'm pretty well pooped after all that work. I will say that I was shocked new bearing were even needed. The wear seemed pretty minimal for 200K miles.
Edit:
Struck out my comment about being shocked. Not shocked anymore. (See below)
Old Today | 01:32 AM
Well I couldn't sleep so here's the wear results for all cylinders. Under this lighting I was able to see a lot more wear that I couldn't see earlier. Guess I'm no longer surprised that the new bearings helped.
Cylinder 1:
Spoiler
Cylinder 2:
Spoiler
Cylinder 3:
Spoiler
Cylinder 4:
Spoiler
Cylinder 5:
Spoiler
Cylinder 6:
Spoiler
hamrtime
Aug 3, 2011 10:44 AM
redturboeclipse
Feb 4, 2010 11:09 PM
Elboy29
May 25, 2008 08:38 PM
toddyfresh
Nov 9, 2006 06:27 PM
