evo engine into gsx????
Old 04-26-2005, 04:57 PM
krentigrwoodz's Avatar
Default evo engine into gsx????
is it possible to drop in a evo8 engine into a gsx????
Old 04-26-2005, 11:45 PM
DSMTalonAWD51's Avatar
Default RE: evo engine into gsx????
no its not possible, the timing belt is on the opposite side, and you dont want to anyway its the same engine with higher compression pistons and better head. For the price of swapping an engine you can make a gsx much faster than an evo.
Old 04-27-2005, 10:40 AM
you could do it it would just require moving of some motor mounts. if the timing belt is on the otherside i would say you would have to place the mounts like a 420a motor. but i do agree that if you were to pull your motor and dump the money you would pay for the other into yours it would be brand new and the internals would be awesome. that is what i would do is rebuilt the motor you have make it better than the motor you are going to buy for about the same price maby a little less money
Old 04-27-2005, 03:49 PM
it will not work. the engine layout is opposite. you could swap with an earlier model evo like an evo3 but u will never find one. build your motor to be faster
Old 04-28-2005, 10:53 AM
Not going to happen bud. Sorry.
Old 04-29-2005, 09:55 AM
ORIGINAL: DSMTalonAWD51
Dont say it could not be done it could it would just take a lot of work A LOT!
Old 04-30-2005, 03:00 AM
ok, correction, anything possible with an infinite supply of money, but realistically, dont count on it.
Old 05-06-2005, 06:44 PM
i was wondering the same thing too, but then i have a 99 gs-t and i was thinking of dropping a evo8 engine in mine but then i don't even know where to get one too... i supposed i should just leave it stock because my bro said that it's also a evo engine already so then i suggested that it be up to u if u do really want to swap it.
sk8dudety
09-20-2007 08:01 AM
atown420
08-12-2007 04:01 PM
kniel023
04-25-2007 06:58 PM
Pribs
03-18-2007 06:26 PM
andauto
02-25-2005 02:18 AM
Quick Reply: evo engine into gsx????
