evo engine into gsx????
Old Apr 26, 2005 | 04:57 PM
krentigrwoodz's Avatar
Default evo engine into gsx????
is it possible to drop in a evo8 engine into a gsx????
Old Apr 26, 2005 | 11:45 PM
DSMTalonAWD51's Avatar
Default RE: evo engine into gsx????
no its not possible, the timing belt is on the opposite side, and you dont want to anyway its the same engine with higher compression pistons and better head. For the price of swapping an engine you can make a gsx much faster than an evo.
Old Apr 27, 2005 | 10:40 AM
get435's Avatar
you could do it it would just require moving of some motor mounts. if the timing belt is on the otherside i would say you would have to place the mounts like a 420a motor. but i do agree that if you were to pull your motor and dump the money you would pay for the other into yours it would be brand new and the internals would be awesome. that is what i would do is rebuilt the motor you have make it better than the motor you are going to buy for about the same price maby a little less money
Old Apr 27, 2005 | 03:49 PM
it will not work. the engine layout is opposite. you could swap with an earlier model evo like an evo3 but u will never find one. build your motor to be faster
Old Apr 28, 2005 | 10:53 AM
patsevo8's Avatar
Not going to happen bud. Sorry.
Old Apr 29, 2005 | 09:55 AM
get435's Avatar
ORIGINAL: DSMTalonAWD51
Dont say it could not be done it could it would just take a lot of work A LOT!
Old Apr 30, 2005 | 03:00 AM
ok, correction, anything possible with an infinite supply of money, but realistically, dont count on it.
Old May 6, 2005 | 06:44 PM
mitsuboi18's Avatar
i was wondering the same thing too, but then i have a 99 gs-t and i was thinking of dropping a evo8 engine in mine but then i don't even know where to get one too... i supposed i should just leave it stock because my bro said that it's also a evo engine already so then i suggested that it be up to u if u do really want to swap it.
sk8dudety
Sep 20, 2007 08:01 AM
atown420
Aug 12, 2007 04:01 PM
kniel023
Apr 25, 2007 06:58 PM
Pribs
Mar 18, 2007 06:26 PM
andauto
Feb 25, 2005 02:18 AM
