speed sensor on 97 Eagle Talon Esi
Ok, I need some help here. replacing the speed sensor on my Talon Esi. car is a 5 spd manual, 2.0L naturally aspirated motor. what I need help with is WHERE THE HECK IS THAT SENSOR? I know its on the tranny, but I cannot find the freakin thing and its makin me wanna torch the car.
also, where is the ignition control module? pictures would be VERY helpful on this.
RE: speed sensor on 97 Eagle Talon Esi
there is no "ignition module" to speak of. All you have for ignition control is a cam and crank sensor, and a coil pack. Everthing else is done via the PCM.
the coil pack is plopped right on top of the valve cover.
and although a failed vehicle speed sensor usually wouldnt cause a no start situation, there IS a problem with one on that particular driveline. it has the potential to short the voltage feed for the cam/crank sensor to ground, thus preventing the car from running.
bishop
08-01-2014 05:37 AM
