speed sensor on 97 Eagle Talon Esi
Old Jul 28, 2006 | 09:40 PM
ninjarider's Avatar
Default speed sensor on 97 Eagle Talon Esi
Ok, I need some help here. replacing the speed sensor on my Talon Esi. car is a 5 spd manual, 2.0L naturally aspirated motor. what I need help with is WHERE THE HECK IS THAT SENSOR? I know its on the tranny, but I cannot find the freakin thing and its makin me wanna torch the car.
also, where is the ignition control module? pictures would be VERY helpful on this.
Old Jul 29, 2006 | 12:15 AM
patsevo8's Avatar
Default RE: speed sensor on 97 Eagle Talon Esi
the sensor is toward the back of the tranny. it's located inbetween the bracket that hold the tranny to the motor/chasis mount. the ign module is ontop of the intake manifold.
Old Jul 29, 2006 | 12:52 AM
ninjarider's Avatar
THANK YOU! I cannot say how thankful I am.
Old Jul 29, 2006 | 03:15 AM
ninjarider's Avatar
ok, after looking, I couldnt find anything on the intake manifold, above or below it. btw, would the VSS cause the car to not start?
Old Jul 29, 2006 | 04:36 AM
patsevo8's Avatar
hard to say about the VSS. a lot of things go into making a car not start, and that's what a lot of people don't understand
Old Jul 29, 2006 | 07:33 PM
ninjarider's Avatar
I understand a car requires a lot of complicated things these days to make it work, and that if one thing in one of those systems doesnt work, it'll cause it to not run possibly.
Old Jul 29, 2006 | 08:08 PM
Manybrews's Avatar
there is no "ignition module" to speak of. All you have for ignition control is a cam and crank sensor, and a coil pack. Everthing else is done via the PCM.
the coil pack is plopped right on top of the valve cover.
and although a failed vehicle speed sensor usually wouldnt cause a no start situation, there IS a problem with one on that particular driveline. it has the potential to short the voltage feed for the cam/crank sensor to ground, thus preventing the car from running.
Old Jul 30, 2006 | 12:58 AM
ninjarider's Avatar
Would it potentially damage the crank/cam sensors? I put a new cam sensor in, have the old one still, havent tried crank yet, but the VSS is only $40 so I'm gonna try it.
bishop
Aug 1, 2014 05:37 AM
theshad0xx
Jul 25, 2009 07:18 PM
Tallen
Jul 4, 2008 12:26 PM
artificialboostin
Nov 2, 2007 11:33 AM
theycalmewiteman
Feb 25, 2006 02:45 PM
