Sponsored by:
Sponsored by:
05 galant es cranks no start
Old 03-02-2017, 04:23 PM
Ashley LaVette Daniels's Avatar
Default 05 galant es cranks no start
05 mitsu. Galant es. Have changed oil as needed nd had to get a new starter but that's was last year. Have had no issues since. Decided to use gumout fuel injector cleaner(have used it on my previous cars ((neon, Aveo, integra)). Did as instructions stated(which a lot of ppl say don't follow now after searching similar problems). After riding about 20mins car oil light came on and car stopped running. Checked oil( had plenty). Tried to run codes with obd-ii(mine is acting like it doesn't want to work). It sounds like fuel is not getting to the engine even if press gas peddle. Found that fuel pump was not working. Changed that and fuel filter. Still cranks but does not start. Have disconnected fuel lines in all spots to make sure it's not clogged. Fuel is passing through. I am stumped. Please help.
Old 03-02-2017, 08:29 PM
I have tried to run code again but now the CEL is not on. Will try again nd write update.
Old 03-03-2017, 01:15 PM
Finally a code came up. P0340 CAMSHAFT POSITION SENSOR will be changing it tomorrow and hope it works.
Old 03-16-2017, 08:40 PM
So changed to camshaft sensor and the crankshaft sensor. Still not getting any start. It's cranking but not starting. Still no help anyone?
cod1ak
03-28-2008 08:55 AM
triha
05-14-2007 12:09 AM
95HGeclipse
03-05-2007 10:42 PM
Dookitchen
04-14-2006 02:32 AM
dsfii
05-02-2005 12:13 AM
Quick Reply: 05 galant es cranks no start
